Cockshutt 40 Question
C. Amick
02-19-2001 09:38:27
I have a Cockshutt 40 with a six (6) cylinder gasoline engine which needs to be rebuilt. I am wondering whether or not I will have more in the rebuild than the tractor is worth? Did Cockshutt make this tractor with a diesel engine? Would I be better off trying to find a diesel engine for it even if the diesel engine needed rebuilt?
CAnada Grant
02-19-2001 20:37:01
 Re: Cockshutt 40 Question in reply to C. Amick, 02-19-2001 09:38:27
40 diesel heads can be a problem also manifold on diesel may exit in different place on the allis combine they do on gas ones . All depends if your playing or working this tractor and gas a lot easier to change plugs points etc rather than big bucks into injector pumps etc.
Dave Neubert
02-19-2001 15:04:24
Most people put more in a antque tractor than it is worth but they do it because they like the tractor. They did put a diesel in a 40 but you can also put a 262 out of a Gleaner combine (AC) in it. You can find a use engine.I think Phil Hiesey has some he is in PA. you can find them in salvage yards.
John Ellerbe
02-27-2001 00:35:34
 Re: Re: Cockshutt 40 Question in reply to Dave Neubert, 02-19-2001 15:04:24
The engine in Cockshutt 40 is a 230 cu. Buda. There is a Diesel 40 as well. using the same basic block. Buda Engine Co. was purchased by Allis Chalmers in 1953. The 6cyl. diesel used in the WD-45 AC tractor is basicially the same as the Cockshutt diesel. The 262 gas/diesel engines used in AC D-19 tractors will fit in a Cockshutt 40. This said the Buda engines are not hard to get parts for. And good machine shop that does work on industrial engines can order parts for it. Hope this helps good luck! John
