Alternator Retrofit
RCP
02-18-2001 15:46:35
I have installed many GM alternators on old Olivers and Farmalls, and always have problems tucking them under the body work. Are there any smaller alternators that have internal regulators and v-belt drives that will work for this type of retrofit?
John de Marrais
02-22-2001 20:08:18
 Re: Alternator Retrofit in reply to RCP, 02-18-2001 15:46:35
I've had clearance problems on a few machines, also, including my Oliver Cletrac HG. I stopped using Delcos, and now use the Fuji and Nippodenso alternators off of 1985-91 Subarus. The normal size cars have a 4.5" diameter alternator with internal regulator, and the little 3 cylinder Subaru Justys of the same year range have an even smaller one (4") diameter. Our local junkyards get $25 apiece. The former has the same shaft diameter as a Delco. The latter and smallest needs a different pulley, but has an internal fan. For extreme problems the Isuzu Imark has an even smaller alternator.
RCP
02-23-2001 04:24:35
 Re: Re: Alternator Retrofit in reply to John de Marrais, 02-22-2001 20:08:18
Thanks for the info, I will start looking for one of these.
Bob M
02-19-2001 17:02:36
A buddy of mine has a new Deere front-mount mower (model 1420??) powered by a 3 cyl water cooled gas engine. The alterator is a 40 amp unit made by Hitachi. Looks like a standard alternator only about half as big - about the size of two hockey pucks stuck together. You could probably fit one almost anywhere. Only downside is knowing how Deere prices run it's probably a $250 part!
Might also inquire at Denny's Carb Shop (937-368-2304) - seems to me they catalog a compact alternator.
