Oliver 70 Rears and trans
M Kuhns
02-17-2001 20:37:52
I was wondering if anyone knew whether or not if Oliver made high n low speed rears for the oliver 70s. I use a 70 for pulling anique at a 3 MPH pace. I am running higher RPM's than factory and first gear at factry RPM's is a little faster than 3 MPH. I also have another 70 that isn't running at the present time that I thought when I pulled it before had no problems staying at 3MPH running over factory RPM's. I know in the 77's and 88's they had several different ring and pinion gear ratios. I was wondering if anyone knows if the same applies to the 70's. I was told by another person that they only put in one gear ratio. Any information would be appreiated.
larry
02-18-2001 08:02:44
 Re: Oliver 70 Rears and trans in reply to M Kuhns, 02-17-2001 20:37:52
The 70 had differant ratio ring and pinions.Any tractor on steel was slower.The parts book shows 4 differant numbers, some say low speed ,some don't.
