S55 steering colum top bearing
Delbert
02-10-2001 12:15:16
The new bearing for the top of the steering colum extends above the tube. The dealer says it is the correct bearing,although there is a number change from what I ordered. I have a 1954 S55. There is another part number in the dealer parts book for the steering colum with an "AS" suffix, my book does not show this, how can I get the bearing to work short of having the steering colum tube cut out at a machine shop. Has anyone had this problem. I got a new steering wheel from the dealer,it comes as A kit which is the wheel and the center cap that appears to snap in rather than fasten with a screw, it is not an idential replacement but is verry close, cost $145.00.
Allen Michiels
02-10-2001 20:07:51
 Re: S55 steering colum top bearing in reply to Delbert, 02-10-2001 12:15:16
I had the same problem on my 550 the bearing cup extends past the column. I cut it off flush with the column and used the old spring works just fine. Hope that helps if you can not find the correct cup.
Paul Stanley
02-10-2001 15:19:32
My book says it should be a 1ES-6779 and doesn't indicate any revisions.
Delbert
02-10-2001 18:10:12
 Re: Re: S55 steering colum top bearing in reply to Paul Stanley, 02-10-2001 15:19:32
Paul my book agrees with yours. The parts man said that number has been changed, the new number is 72503195, it doesn't work. The dealer's parts book shows two numbers for item #25 1ES-6753 and 1ES-6753AS which has a later serial no, must mean a newer type steering colum. A friend is a Ford collector, he says the steering gear box looks similar to Fords I may try one of those bearings. Thanks for the reply. Delbert
Mark
02-11-2001 04:43:59
 Re: Re: Re: S55 steering colum top bearing in reply to Delbert, 02-10-2001 18:10:12
I just went through this. The dealer said the bearing gets pressed out, and the bearing cup is
cut down to the right size. Then the bearing goes back in, and the whole assembly goes into the steering column tube. Apparently this one bearing assembly will service a wide range of tractors, that's why they did this. You want the lower half of the bearing cup, this has the flange on the bottom to hold the bearing in. I did this and mine works fine, although there isn't enough room for the spring anymore.
