1650 Hydraulics
Bacman
02-05-2001 18:11:00
The remote cylinder extends good but the engine must be at high rpm's to pull the cylinder plunger back. It barely moves. It's the same on both sides of the dual remotes. The 3-point works good. Any ideas? Thanks.
Richard
02-06-2001 03:53:13
 Re: 1650 Hydraulics in reply to Bacman, 02-05-2001 18:11:00
Does it make a buzzing noise like the pressure relief valve is going off? There are adjustable restrictors valves on the side of the hydraulic section on the 1650 (located on the very top section - Regular screw driver slot with lock nut). Back these out a little at a time and see if it helps. If you back it out too far the implement may start bouncing, simply turn the restrictor in a little.
Also, when using DA cylinders, the bypass valve should be screwed in all of the way, if SA then it is suppose to be backed out about 5 or 6 turns. The bypass valve looks like a bolt sticking out with a lock nut, on the front right section towards the floor plate.
I'm not sure if either one of these will fix your problem but it did fix mine. I'm sure others in the forum will also help.
