Wide front 88
JS IN
02-02-2001 18:30:48
I have 88 with wide heavy cast iron tube. I want to adjust front axle, however where each side tube inserts in center tube thay are rusted tight. Have tried penetrant, heat and even ratchet com-a-long front lower hub to rear axle with pressure while applying heat. I have almost given up for fear of damaging the front end knowing parts will be impossible to find.
Any suggestions?
Scott Green
02-03-2001 06:08:19
 Re: wide front 88 in reply to JS IN, 02-02-2001 18:30:48
I would not be in a hurry doing that project. I would spay a good penetrating oil on it every day for about a week. Two good penetrating oils are "Liquid wrench" and "PB Blaster". Tapping the axle with a good size hammer or small sledge hammer after every spraying of oil will help loosen the rust. That project still may not be easy , but that is how I would start it out. Also , if your useing "WD-40" as your penetrating oil , your just wasting your time and money.
