Oliver engine block?
KELLY
02-01-2001 09:33:14
I have a engine block, complete with head, crank
etc. i was told by previous owner of house that it went to a " oliver orchard crawler? it is green under the dirt, and has a 2"x 4" silver plate with various numbers on it. It is a four cyl.
My question is : could anyone help me identify it.
thanks kelly
larry
02-01-2001 10:05:01
 Re: oliver engine block? in reply to KELLY, 02-01-2001 09:33:14
Yes ,but the letters and numbers off the plate need to be in your post.
kelly
02-01-2001 11:33:44
 Re: Re: oliver engine block? in reply to larry, 02-01-2001 10:05:01
the numbers on the silver plate are: 15
IXK3 3-1/8x4
008 006
also found numbers on block: 294740 2 2246
larry Wolfe
02-01-2001 14:41:54
 Re: Re: Re: oliver engine block? in reply to kelly, 02-01-2001 11:33:44
Thats a hercules IXK3 engine, the other numbers are bore and stroke.This engine was used in HG oliver crawlers maybe evan a OC3 a newer model.Allso used in avery A tractor. 123ci.This is the same series of engines as the IXA,IXB.If it where a good useable engine some one might want it,lots of the old things being restored.
