Carburator Adjustment
Jim
01-04-1999 12:29:34
I have an 88 with a Marvel carburator. I just rebuilt the carburator but need instructions on
how to make the final adjustments to the idle and power adjustments. The IT manual, unfortunately does not cover this. Does anyone
have any ideas?
Thanks,
Jim
Paul Stanley
01-05-1999 07:09:33
 Re: Carburator Adjustment in reply to Jim, 01-04-1999 12:29:34
The only carbs I have listed for the 88 are the Schebler and the Zenith. Are you sure about the make of the carberator? Schebler TSX-374 or Zentih Part No. 11580 Model 267-8. Again, this line is for the cut off I always
Jim
01-06-1999 09:14:38
 Re: Re: Carburator Adjustment in reply to Paul Stanley, 01-05-1999 07:09:33
I took it to an Oliver dealer and that is what
they told me. I probably need to recheck the
number on it. It has a brass tag on the intake
neck with a number.
Thanks
Dennis H.
01-06-1999 19:09:42
 Re: Re: Re: Carburator Adjustment in reply to Jim, 01-06-1999 09:14:38
The carb should be a Marvel Schebler. You should have two screws, one for the idle curcuit and one for the high side. Screw both in until lightly bottomed and back oth back out 1 1/2 turns. This should get it to run, then put the throttle on full and turn the high side in until it stumbles and back it out(counting the turns) until it boggs. Return the screw inward to 1/2 way between these points. Now put the throttle to idle and repeat the process for the idle adjustment screw. I usually repeat the same process for the high side a second time because sometimes it will change. Then set the idle speed with the screw on the throttle linkage and you are done. No biggy, if you have questions write back...
