Split manifold Oliver 70
CLF
01-19-2001 18:44:34
I've recently become interested in trying my luck at a tractor restoration. I've owned a 1650,
1955,and currently have a 1655-all have been great
tractors. So my 1st choice would be an older Oliver. I've found a model 70 that seems very staight---good tin, complete with all parts except
side curtains. The tractor has 2 exhaust pipes coming out of the hood one on each side of the exhaust manifold. Is this an aftermarket addition
or factory option? Or were all 70's made like this
in certain production years? If it is factory are they rare? And one more thing, What's a fair price
for it? It doesn't run and has been sitting outside for years.
Scott Green
01-19-2001 19:04:00
 Re: Split manifold Oliver 70 in reply to CLF, 01-19-2001 18:44:34
CLF , The two main things on the Oliver "70" tractors that put them to rest were the 40" rear tires and the exaust manifolds. You should have one stack going up through the hood. One of the two pipes you have on your tractor crossed over , under the hood , and tied into the other one. A muffler was used to cross over. When the exaust manifold had gotten bad enough , people just put two stacks up through the hood as you described. You can now buy remanufactured intake and exaust manifolds for the Oliver "70" tractor. But for years you couldn't.
rooster
01-19-2001 21:52:44
 Re: Re: Split manifold Oliver 70 in reply to Scott Green, 01-19-2001 19:04:00
Scott, where can I find remanufactured manifolds for the 70? I can get brand new ones for $400 a piece. What do the remanufactured ones cost and who makes them? Thanks.
Scott Green
01-20-2001 05:08:14
 Re: Re: Re: Split manifold Oliver 70 in reply to rooster, 01-19-2001 21:52:44
Sorry , When I mentioned remanufacturing , I ment that the manifolds were now being made again. Not refurbish the old ones.
Joe
07-06-2001 05:38:37
 Re: Re: Re: Re: Split manifold Oliver 70 in reply to Scott Green, 01-20-2001 05:08:14
Where can I find to buy, an Exhaust manifold for an Oliver 70? Thanks for any info....
