Oliver 1855 Radiator
Sam M.
01-15-2001 14:27:46
Anyone know where I can find a new or quality recored radiator for an Oliver 1855 tractor besides the Agco dealer . Mine has sprung a major leak which I am not sure can be repaired . Any input would be appreciated .
Shepherd
01-19-2001 09:45:29
 Re: Oliver 1855 Radiator in reply to Sam M. , 01-15-2001 14:27:46
Dont know where you are located Sam, but the two places I use for good used Oliver parts are Farmersville Equipment in Pa or Wisconsion Tractor Parts 1-877-530-2010. I dont know if it is worth shipping a heavy item like that or just buying a new one, you will have to see what they have.
Sam M.
01-24-2001 09:17:29
 Re: Re: Oliver 1855 Radiator in reply to Shepherd, 01-19-2001 09:45:29
Thanks Shepherd . I am in Upstate South Carolina . I have been unable to find a radiator , new or used , for an Oliver 1855 anywhere except through Agco . I have found a new radiator for a White 2-105 but I do not know if the 1855 and 2-105 used the same radiator . I have taken mine out and had the problem area welded . It was tested with high pressure air and the weld held up well . I will put it back in and see how it holds up with water during actual operation . If the weld does not hold , I will need a replacement and will call one of the places you suggest . I appreciate the names because I can call them for other parts as well . Thanks again .
