Loose over/under in 1955
Jake in NY
01-13-2001 19:32:01
The over/under in our brand new used 1955 is quite a bit looser than our old 2-105 was. Is this just normal wear and tear or is this a problem? And can we fix it for a reasonable price or should we just live with it?
Jake
larry
01-14-2001 08:35:24
 Re: loose over/under in 1955 in reply to Jake in NY, 01-13-2001 19:32:01
What is loose the shafts,the shift leaver,or the shifting. Those units had a lower shift preasure kit for them, it made them shift slower.
Jake in NY
01-14-2001 15:40:23
 Re: Re: loose over/under in 1955 in reply to larry, 01-14-2001 08:35:24
There seems to be a lot of play in the lever itself. It's bad enough that it's difficult to be sure what range you're in. I would estimate that the lever has about an inch of up and down play at the handle. Jake
Wrenchbender
01-14-2001 18:20:01
 Re: Re: Re: loose over/under in 1955 in reply to Jake in NY, 01-14-2001 15:40:23
The pin in the arm that moves the spool in and out of the O/U sometimes wears and that causes excess movement in the lever. Follow the linkage down to the O/U and see if that is where the slop is. I believe that pin is replaceable and available from agco. WB.
