Crankshaft rod journals
Possum
01-13-2001 16:23:39
Anybody ever seen crankshaft rod journals worn at
a taper. They taper about .002 from back to front,
I checked the rods and they are all straight. This
is on an Oliver 70. Any thoughts?
Possum
01-14-2001 23:02:36
 Re: Crankshaft rod journals in reply to Possum, 01-13-2001 16:23:39
Thanks for the info guys I think I found the problem. I put the crank and bearings back in the
block and found a very excessive amount of crank
end play.
Gary
01-14-2001 15:06:58
This is a common problem on the older continental engines. Have the rods checked for alighnment, turn the crank and you shouldn't have any problem. Also most of the time the front main brgs. will be wore alot worse than the rear one's.
larry
01-14-2001 08:31:00
The piston holes don't line up with the crank journals,look to see if they are offset like a s77.
