Oliver 60 info needed.
Scott F
01-12-2001 15:17:36
Does anybody know the torque specs for the head bolts on an Oliver 60? Also could someone tell me valve adjustment for an Oliver 60. After shaving the head to true it I should adjust the valves. I appreciate any help. Can't wait to get this baby running again after who knows how many years. The guy I got it from said it did not run when he got it and that was more than five years. Thanks.
Geoff
01-16-2001 17:16:20
 Re: Oliver 60 info needed. in reply to Scott F, 01-12-2001 15:17:36
The head bolts should boe torqued to 77 ft/lbs. The avlwes should be adjusted to the following. Intake Exhaust
Maximum .011 .013
Average .010 .012
Minimum .009 .011
For more information you can look at my web site at www.geocities.com/olivercollector. go to my pages and then to Oliver 60. Hope this helps
Cal
01-13-2001 12:18:26
The Oliver 60 Service Manual said the head bolts are torque to 77 ft. lbs.
Dick
01-13-2001 04:15:46
I looked through what I have at home on the Oliver 60 and did not find the torque values for it. Like engines run from 50 ft lbs to 60 ft lbs.
The valve clearances are Intake hot .009 cold .011
exhahst hot .011 cold .013
