PTO on 1850
TC
01-12-2001 08:45:09
I have an 1850 that my father gave me when he quit farming a couple of years ago. The thing I am trying to figure out is how to use this tractor for PTO work such as pulling a moco and a round baler. The only PTO work it had ever done was to pull a silage cutter and it was good for that. The PTO speed is rated at 2400 and I hate to hear it scream when it doesn't need the power. The Fords I currently used the PTO speed is 1900. I have considered setting it up on 1000 shaft and idle the motor back has any one been using theirs like that? I really need to use this tractor because setting is probably alot worst on it than using it. In this part of the country small farmers can't afford to row crop so all we can do is fool with hay. I hate to not try to use it because it was one of the few tractors that was bought new on the farm and it is like family. thanks, TC
Johnnie
01-15-2001 18:27:30
 Re: PTO on 1850 in reply to TC, 01-12-2001 08:45:09
I agree with Sheperd let her scream. Let the neighbors know that Oliver is in the field.
Shepherd
01-12-2001 09:01:31
It is great so see some of these old Oliver still out there doing the work. As to the PTO, I would not try switching the PTO to 1000. Couple reasons, you can easily over RPM the machine you are running and damage the machine, also by going to the 1000 you are cutting the RPM's in half and nearly doubling the tork on the tractor, putting extra stress on the tractor and the PTO, possibly causing breakage. The tractor was designed to be run at a certin RPM in order to reach 540 for a reason, do not change that. Besides if this tractor does not run much and is a diesel??? it needs to get out and scream. Remember diesel engines, unlike gas are designed to run at or near full throddle, and need to. Personally I love to hear the Oliver diesels do their work. Just my 2 cents
