1655 block heater?
jeff
01-04-2001 19:10:55
i found one those heaters like one of you suggested. but its only a 1000 watt.
it has the thermostat and flows from drain plug
to water elbow. question is ,on the 1655, is the 1000 watt enough or should i have them order me a 1500 watt? who is using which one out there?
my inclination is bigger is better but is there something i might be missing?
thanx jeff
ps is does look like a wd-40 can
Shepherd
01-05-2001 05:16:52
 Re: 1655 block heater? in reply to jeff, 01-04-2001 19:10:55
It kinda depends on where you are and how cold it gets. I keep my tractors in a pole shed here in Virginia and it does not get below zero very much, so I can get by with the 1000 watt I have on the one tractor, but I prefer the 1500 watt ones that I have on the other ones. I will agree with you that bigger is better and hotter. Depends on how cold it is getting where you are and if the tractor is inside or out.
jeff
01-05-2001 06:21:14
 Re: Re: 1655 block heater? in reply to Shepherd, 01-05-2001 05:16:52
in northwest pa
its in a pole barn but its been below freezing
since about dec 15th and closer to 10 deg
every night. the 1500 watt sounds like the choice
thanks jeff
dave
01-04-2001 19:49:57
I'd get at least the 1500 watter. I have a 2000-watter I put on my White 2-85 and that works just fine for these North Country winters.
good luck
