Oc3 engine swap
Canada Grant
01-02-2001 19:26:28
Tractor jocky has oc3 with blade and motor in parts says he is going to put diesel from OC46 into oc3 as rear end done on oc46 . Will this work? I can,t see oc46 for 5 feet snow [exhaust pipe showing "thats all"] and dug around oc3 [only 3 feet snow] so this isn,t going to happen tomorrow. Any ideas?
Gary Hearn
01-03-2001 17:45:31
 Re: Oc3 engine swap in reply to Canada Grant, 01-02-2001 19:26:28
Having owned both OC-3's & 4's, I would much rather replace the rear in the 46 than have an OC-3 w/ a 3 cylinder diesel. The Oc-46 has spot turn clutches, a 4 speed transmission and probably a reverser that make it a far superior outfit.
The rear on the OC-46 was made by Clark and is the same as a Case 310.
Seth Andersson
01-09-2001 17:06:33
 Re: Re: Oc3 engine swap in reply to Gary Hearn, 01-03-2001 17:45:31
Hallo! Sweden is calling. I am an owner to an old OC3, gasoline engine, and I need to restore the engine. I asked in Yesterday's tr. last year for
spareparts and get a tel.nr. to some Landis in PA,
and I talked even with them, but I have lost the tel.nr. Can anybody help me to get it once again.
Seth Andersson, Lule�, Sweden
