Stupid Q: Where is it?!
Steve in CA
01-02-2001 12:54:58
Hello all. I just purchased a nice 88STD. The operators manual shows the ID plate below the dash. I don't have anything there. I do have something that looks like an ID plate riveted to the frame between the belt pulley and brake housing. It's Oliver shield shaped. It's been painted over, so I can't make out if it has a serial number. Is this the ID plate? If not, are there any casting codes to look for that will help me determine the year? Too bad Oliver didn't stamp the serial number directly on the frame, like my two Cockshutts...
Thanks!
Mike M (WA)
01-02-2001 19:35:03
 Re: Stupid Q: Where is it?! in reply to Steve in CA, 01-02-2001 12:54:58
Yeah, you found it. That's exactly where the plate was on the "880" for $900 that I drove 80 miles to look at- which turned out to be an early 88, and wasn't even in as good a shape as he said, never mind the "slight" mix-up in model numbers. . . Oh, well, it was a pretty drive- and he had a Cockshutt 35 right beside it, that I ended up with!
Canada Grant
01-02-2001 17:17:56
Untill 1952 on the frame then up on dash after that. Sometimes you can see casting dates on frame on inside beside motor but you may have to remove engine and cleanup interesting if you find it but a lot of work just for interest sake!
Scott Green
01-02-2001 17:11:36
Hi Dave , The standard tractors have the serial number plate down where you said it looked like a serial number plate. Yes , you found it.
Dave N
01-02-2001 15:31:10
Sounds like you got a early 88 does it have the grill that looks like a 70 grill. the early 88 I looked at had the tag in the area you are talking about.
Steve in CA
01-03-2001 13:17:48
 Re: Re: Stupid Q: Where is it?! in reply to Dave N, 01-02-2001 15:31:10
No, it's not one of the early 88's. Sounds like it's 1952 or older. I'll try to take the paint off the tag and see if I can make it out. Thanks for all the replies!
