MORE POWER!!!
randy
12-31-2000 17:20:21
Hey guys I need your help. I have an OC-3 that I just put new points condenser and coil on. Its runs great when I can get it started but that's a struggle. Also it stalls out very easily now. No power. Timing? Gap? Plugs? Carb? `
D13
12-31-2000 19:15:52
 Re: MORE POWER!!! in reply to randy, 12-31-2000 17:20:21
I'm assuming it ran before the new parts, without this problem. Make sure you have the correct coil and the correct coil polarity (6 vs 12 volts, + vs - ground). Check you wires too. But if it starts hard and runs great I'd check the timing and dwell. Often, and engine that "hesitates" during cranking has the ignition too far advanced or the dwell off.
Canada Grant
12-31-2000 18:00:49
I purchased a HG that would not start and I went to the truck pulled out a set from a 8n and have ran on them for 5 years . I left the other plugs behind on the guys workbench hope he threw them out !
