OLIVER 1950 GM diesel
dave
01-01-1999 11:01:14
Just bought a 1965 oliver 1950 out of the wheat country of Montana. Had to replace one bull gear and bull pinion(bad teeth) new brake discs allthe way round. tires are worn but good casings(no breaks).Hydra-power works good. Any body have any tips on tuning the engine? It runs now, any way to make it run better? what a puller!!! 13,000 pounds worth.
Adam
01-04-1999 22:44:17
 Re: OLIVER 1950 GM diesel in reply to dave, 01-01-1999 11:01:14
You could adjust the valve clearence. And have the injectors cleaned and tested and the injection pump tested and adjusted But work on injectors and injection pumps is not cheep. Good luck
