What motors will fit my 1650
glen
01-01-1999 09:57:44
i just got a 1650 with a bad engine but every thing else is fine my freind has a 1800 with a good engine but the tranny is out of it he said he would sell me the 1800 and i was wondering if i could put that motor in the 1650 and im interested what motors i can swap in to the 1600-1855s thanks
Danny
03-26-1999 15:10:27
 Re: what motors will fit my 1650 in reply to glen, 01-01-1999 09:57:44
Glen, I think you would be better off rebuilding
the original motor in your 1650 if the block is
ok. You can get into a whole lot of problems changing the engine in an Oliver with that angle
that the Olivers used for mounting the engine.
The 1800 engine definetly won't fit as the 1800 had to use a larger frame to acomodate it.I also
think that the Hydra Power Drive in an 1800 is bigger, so it won't fit your 1650, either.
A full rebuild kit for the 283 Waukesha your 1650 uses is usually priced very reasonably,readily available, and it's a lot easier work. Just an opinion. Danny.
Don
01-04-1999 02:32:16
Glen, 1650 took a 283 Waukesha and the clutch and bellhousing were smaller. The 1750 has a 310 Waukesha and you would have to re-work the frame to fit engine and tranni. It still may be to big.
The 1850 took a Perkins 354. This won't fit at all. You can contact Cummings and inquire about a 5.91. This engine is used to rebuild the olivers.
Bob M
01-03-1999 12:10:40
My wife's dad has both a 1650 and 1850 (1850 is essentially a slightly modernized version of the 1800). Anyway the block on the 1850 looks both wider and longer than the 1650 - I doubt it could be shoehorned into the 1650. I also question whether the Hydrapower and transmission on the 1650 could reliably handle the torque of the larger 1800 motor.
Bob
