Super 55, what to look out for
Paul Stanley
02-15-1998 11:10:26
Going to look at a super 55, diesel today. Is there anything I should particularly look out for on this model. I have no experience with diesel motors. The fellow is aking $2,600 Canadian ($1,800US).
GARY PETERSEN
02-15-1998 14:28:44
 Re: Super 55, what to look out for in reply to Paul Stanley, 02-15-1998 11:10:26
: Going to look at a super 55, diesel today. Is there anything I should particularly look out for on this model. I have no experience with diesel motors. The fellow is aking $2,600 Canadian ($1,800US).
look at 1 - oil press - excessive motor noise 2 - smoke from exaust 3 - steering sector - not good design and expensive to fix 4 - center castings - main & top
price is ok if nothing major is wrong- but- diesels are hard starters in cold weather(or if rings,valves,and/or injectors are in poor condition.
good luck
Bob Skurka
02-16-1998 05:24:24
 Re: Re: Super 55, what to look out for in reply to GARY PETERSEN, 02-15-1998 14:28:44
My Super 55 is a diesel and, as all diesels are, it starts hard in cold weather. This is just because of the design of desiel engines. As your posting appears to come from Canada, make sure the "preheater" is operational. A button on the dash needs to be depressed and held down, the intake manifold will begin to heat rapidly and will continue to heat as long as the button is depressed. The manifold will be warm to the touch very quickly. MAKE SURE YOU SEE THE TRACTOR WHEN THE ENGINE IS COLD. If the owner had it running just before your inspection, you won't be able to tell. Don't let people scare you away from diesel engines, but don't buy a crappy tractor because of one, either.
Paul Stanley
02-20-1998 21:11:54
 Re: Re: Re: Super 55, what to look out for in reply to Bob Skurka, 02-16-1998 05:24:24
Thanks for the tips. I thought I posted a reply, but I guess it was in Tractor Talk. I bought the Super 55. It's getting picked up tomorrow. It is in great shape and I feel I paid a fair price. Needs some minor stuff right now. I need to rebuild the generator and put in a new battery and that's about it until I get ready to restore it. can't wait to get my first tractor home.
GARY PETERSEN
02-16-1998 21:24:42
: My Super 55 is a diesel and, as all diesels are, it starts hard in cold weather. This is just because of the design of desiel engines. As your posting appears to come from Canada, make sure the "preheater" is operational. A button on the dash needs to be depressed and held down, the intake manifold will begin to heat rapidly and will continue to heat as long as the button is depressed. The manifold will be warm to the touch very quickly. MAKE SURE YOU SEE THE TRACTOR WHEN THE ENGINE IS COLD. If the owner had it running just before your inspection, you won't be able to tell. Don't let people scare you away from diesel engines, but don't buy a crappy tractor because of one, either.
BOB - WHAT I AM TALKING ABOUT IS THE "EXTRA" HARD STARTING THAT COMES FROM THE WEAR AND TEAR OF A TRACTOR THAT IS 43 YEARS OLD! ALSO THE NEW DIESELS START LIKE A DREAM COMPARED TO THOSE BUILT IN THE FIFTY'S. COMPRESSION AND FUEL INJECTION PLUS HIGH ROTATIONAL SPEED OF STARTER IS ALL THAT FIRES THESE BABIES - IF ANY PART IS LACKING IT WILL NOT START! PREHEAT HELPS BUT MAY NOT OVERCOME THE LACK OF THE HEAT OF COMPRESSION.
