2255 MFWD rims?
Adam
12-24-2000 22:57:07
I have 14.9-26 tires on the front of my 2255 and the current rims will only go to 66" on center. I'd like to get to 60" on center to avoid damage when cultivating. Did oliver offer a rim with more offset? Is there an after market supplier that handles these or would custom make one? Dad had his cut and rewelded I would rather avoid this. Thanks, Adam
Dsl
12-26-2000 19:04:58
 Re: 2255 MFWD rims? in reply to Adam, 12-24-2000 22:57:07
Something to consider here--in the owner's manual for my 2255 FWA:
"NOTE: DO NOT ADJUST FRONT WHEEL TREAD WIDTH LESS THAN 70-3/4 INCHES ON FOUR-WHEEL DRIVE TRACTORS AS FRONT WHEELS WILL CONTACT FRAME WHEN TURNING."
Adam
12-27-2000 07:02:07
 Re: Re: 2255 MFWD rims? in reply to Dsl, 12-26-2000 19:04:58
I've got them at 66" on center since right after I bought it. The 14.9-26 tires do not contact the frame. To go to 60" on center I have to modifi the axle carrier a bit on the back side but it would work other wise. What tire size do you have?
adjustment
12-25-2000 18:44:40
What will changing the wheels side to side do for your fit. Right to left and left to right.
