1850 Deisel
Brian
12-22-2000 09:50:59
I want to do some tractor pulling with my 1850.
I was woundering if it is worth it to put a MW Turbo kit on it. And if it is could I still farm with it. Because a friend of mine has an IH 826
that he put a MW Turbo kit in and then blew the pump on it. Well that tractor also turns 140hp.
I just want to know if its worth it to me and i will not blow up the motor Thanks Brian.
Shepherd
12-27-2000 05:55:33
 Re: 1850 Deisel in reply to Brian, 12-22-2000 09:50:59
I have an 1850 turbo. What I did was when my Perkins expired at 4200 hrs from a failed oil pump I took an engine out of a 2-110 white and installed it into the Oliver. That engine was a series 4 Perkins and is already turbocharged and we turned it up some and worked on the charger. I now have a field tractor that operates very well at 135 HP. I dont pull it, but it would be mean if I did. I would not advise putting a charger on the origional seris 1 Perkins that is in that tractor, but maybe look at finding an engine that is already set up for a charger. There is a lot of the newer Perkins Turbo engines out there in Massys and Whites.
Jim Mc.
12-26-2000 13:41:01
I was also curious about putting a turbo on one of our 1850's,while rebuilding the engine I had achance to talk to an experienced Perkins mech. and he advised me against it, he claimed the turbo
354 block had a better oil gallery system and to put a turbo on a non turbo engine would shorten engine life considerably.Myself being the practicle type and trying to support a family on 60 milk cows, decided against it.I do know that some guys have done it and seem to get away with it.One thing you might find interesting is the 354 Perkins were used in some marine applications,they used a large turbo and operated at 3000 rpm's turning out 190 hp.!! like to see an old 1850 go with one of them in it!
B A Star
12-26-2000 18:17:30
 Re: Re: 1850 Deisel in reply to Jim Mc., 12-26-2000 13:41:01
Take it from one whom has had a lot of experience with the 1850 engine. It was a very good engine when the fuel delivery was at factory specifications, howvever when fuel delivery was increased it had some problems. Perkins, owned inpart by Massey Ferguson built the 354 in many ( 54 I think )versions that were used in many applications. The serial number will tell you the version and where it was manufactured. The 1850 used a 354U engine. The engine is a (no dot) engine or the basic engine and "U" identifies that it was built in the United Kingdom. The problem with the 1850 engine is that it does not have coolant passages between the exhaust passages and the valve cover gasket surface. Valve cover gaskets would live at the factory fuel delivery level, however if the pump was "turned up" it destroyed the valve cover gasket. Oliver made many attempts to come up with a gasket that would live, they spent a lot of money attempting to solve it for the customer. Just too much heat in that area when "hopped up". Most dealers turned the pump back when they traded them back in and they eliminated the problem. The 2-105 ( dot 1 )engine had coolant passages around the exhaust ports to allow the gasket to live. The 2-105 was a (dot 1 )turbocharged engine, however it did not have reinforced top ring lands in the pistons and did not have piston cooling nozzles. Again, if fuel delivery was increased it would melt #5 piston first, appearently #5 had less coolant flow around that liner as compared to others. How do I know? I was in charge of warranty for one of the companys larger Branchs in that peroid of time. When I got a call on a melted piston wanting warranty, I would tell them that I could identify the failed piston Number. If we looked at the tractor, we would challange the dealer or customer to allow us to check fuel delivery, that would end the discussion. The 2-85 had steel reinforced top ring lands, Yes, a better piston in a non turbo engine vs. turbo engine, however that was a political deal. Also the 2-110 ( dot 4 ) engine had reinforced top ring land pistons. Of course people want to install the 2-110 pistons, however you will have to do some machining to accomplish it. The 2-105 engine had a drilling from the rod bearing the length of the connecting rod to deliver lube oil to the wrist pin in the piston. The 2-110 engine has "TeePeed" wrist pin end connecting rods vs. the "non-teepeed" in the earlier engines. Do not use 2-110 connecting rods in the earlier engines as they do not have the drilling to deliver lube oil to wrist pins. 2-110 has piston cooling nozzles to lubricate and cool the under side of the piston. Wrist pin failure will occur very rapidly if 2-110 rod are used. In other words you will have to machine the wrist pin end of the 2-105 rod to match the 2-110 wrist pin end. I have a friend that had 2-110 pistons in his 2-105 at 140 Hp and it lived for 4000 hrs., of course he used his head and did not lug it for long peroids of time.
MCL in IN
12-25-2000 18:57:17
That is the 354 Perkins. I know White used that engine in other applications--some turbo some not. We have a 2-105 with the same engine turbocharged. Last time on dyno tested 119 hp. I understand it is newer but the base engine is pretty much the same. Fuel system and manifolds are different. I talked to a guy once who had turbo'd his 1850 to pull and farm both and had no problems.
larry wolfe
12-22-2000 09:56:51
That engine has many trubo versions.If done corectly it should be fine.
