Making front blade / lift for 880
Lazyhorse
12-17-2000 20:08:10
I am thinking about making a front snow (dozer) blade and frame that will fit my narrow front 880. Does anyone have any plans for such a project. I was thinking if I could mount a remote hydraulic cylinder vertically on the front of the tractor, to raise and lower the blade. If I can make a working unit, would the front end support the weight on the blade to lift & move round bales?
P Latta
12-19-2000 16:01:00
 Re: Making front blade / lift for 880 in reply to Lazyhorse, 12-17-2000 20:08:10
My grandfather had a setup like you are proposing on his JD A. He had a plow frame made up of channel steel that bolted on either side the tractor's front frame. This was connected to a frame which supported the plow blade. He used the hydraulic cylinder off his No. 8W sickle mower to raise the plow which was gravity lowered. The blade angle was hand adjustable. The hydraulics came off the back of the tractor. My brother found a dirt blade for this arrangement this past week.
Scott Green
12-18-2000 05:04:21
Just put a loader on it. The tractor will suport the weight.
