1600 Hydraulics
Bob Semrau
12-14-2000 07:24:21
All of this talk about hydraulics has reminded me of a question about my tractor. Some previous owner connected the line in and out ports on the bottom of the hydraulics assembly on the same side as the filter together with a two foot hose. In the manuals it looked like these ports are normally plugged if not used. Is this setup OK ? I can lift large round bales with the 3PT, but sometimes the relief valve chatters when cold. I also get this noise the first time I exercise a remote cylinder after hooking it up. The hydraulics on this tractor are a lot more complicated than my Ford Jubilee !
Thanks ...
larry
12-14-2000 09:18:56
 Re: 1600 Hydraulics in reply to Bob Semrau, 12-14-2000 07:24:21
This should not be a problem as long as you dont move the remote hyd lever for that side.With a hose hooked here you wont blow the relief valve when you push the wrong remote valve.
Bob Semrau
12-16-2000 18:13:23
 Re: Re: 1600 Hydraulics in reply to larry, 12-14-2000 09:18:56
Larry :
Are these ports for a third remote ? My tractor has two remotes (along with the 3 point) and they all work.
These ports are down near the base of the hydraulic unit, just in front of the filter.
Thanks
