SETTING GOVENOR ON OC-3
JOE
12-12-2000 15:53:25
HOW DO YOU SET THE GOVENOR SPEED ON A 1953 OLIVER OC-3 ?
Delbert
12-14-2000 07:54:10
 Re: SETTING GOVENOR ON OC-3 in reply to JOE, 12-12-2000 15:53:25
This is from my HG copy of origional owners book, the adjustmet should be the same. For governars with bumper screws. With hand throttle in wide open position and carburetor butterfly lever in the wide open forward position,adjust governnor rod length so that it comes 1\16 to 1\8 inch short of lining up with hole in butterfly lever. Start and warm up engine. With throttle wide open, adjust the bumper spring in gradually until the governnor surge disappears and engine operates smothly at all speed ranges. Bumper screw should be screwed in only far enough to eliminate surge as over adjustment will result in an excessive"No Load" speed and a sluggish operating governor. After adjustment is complete, tighten the lock nut on the bumper spring screw. The paragraph above says to adjust the rod clevis at the hand lever quadrant to adjust the high speed stop rather than to rely on the adjustment at the lower end of operating lever at the governor. Delbert
