Removing engine/clutch from 70
Von WC Ohio
12-06-2000 20:26:03
I need to know a few details on removing a engine and clutch housing assembly from a 37 Oliver 70. Coupler to transmission shaft and all other connections are off. Would like to remove all as one unit. Need to know the details on front of the engine mounting to pedestal (cone shaped) cast in bathtub and tips on removing pins that go through frame into clutch housing. Any slick way to remove these two pins ? Cannot drive them because of the angle when the clutch inspection cover is removed. I am thinking a slide hammer or some sort of pulling arrangement. Did Oliver have a special tool for this? They appear to have never been out. On the front engine mounting support is there any rigid attachment. There appears to be no bolt holding this on this particular tractor or does it just sit on this cone shaped casting on a pin ?
Ideas and suggestions appreciated
Von WC Ohio
Possum
12-06-2000 21:33:04
 Re: Removing engine/clutch from 70 in reply to Von WC Ohio, 12-06-2000 20:26:03
Von,
For the front mount there is a stud in the front
gear case that goes down through the cone with a
nut on the bottom side.Be careful removing the engine as there are shims under the front mount
and shims between the tub and the bell housing
in the rear on both sides to align the clutch
output to trans input shafts. As for the rear,
yes oliver had a special tool but I made on at home. Take a two inch piece of pipe big enough
the pin will fit inside drill a half inch hole
in a piece of thick flat stock big enough to fit
on top of the pipe screw a piece of allthread
into the tapped hole in the outside of the pin
place the pipe then the flat stock over the all
thread put a nut on the allthread and you should
be able to draw the pins out. Don't forget to
remove the set screws and locknuts on the rear pins.
Von WC Ohio
12-07-2000 19:13:18
 Re: Re: Removing engine/clutch from 70 in reply to Possum, 12-06-2000 21:33:04
Possum,
Thanks for the info that is exactly what I was looking for. Your setup sounds like it will work real slick.
I appreciate the help !
Von WC Ohio
Possum
12-07-2000 21:15:41
 Re: Re: Re: Removing engine/clutch from 70 in reply to Von WC Ohio, 12-07-2000 19:13:18
Let me know how it turns out. Are you pulling the engine for an overhaul? GOOD LUCK
