Pulling Tractors
Rich
12-06-2000 08:33:42
Thinking about pulling a 66 or a 77 in the local antique pulls. In reading the rules it appears that the 66 is at a real disadvantage, the local rules allow the A-C guys to run D-17 motors (226 ci) in their WC's etc. The 66 is only about 155 stock. The 77's are not allowed to pull in weight classes under 4000#. And even at that the 77 is normally about 200 ci. Is this why we see very few Olivers in the light weight classes. Is there something I am missing?
missery
12-08-2000 17:40:26
 Re: Pulling Tractors in reply to Rich, 12-06-2000 08:33:42
I pull a 66 in the 3500,4000,4500 lb clases. do real well in the 3500.it is on pressed steal wheels w/11.2/38's B F Goodrich irr. tire.the club i pull in is stock antquie.my 66 is pretty tough to beat. have no problems with the john deeres.now and then i get beat by a 230 international,(i have to let Dad win sometimes hehehe) missery.
Rich
12-08-2000 20:13:38
 Re: Re: Pulling Tractors in reply to missery, 12-08-2000 17:40:26
I am very surprised that you can compete in the 4000 and 4500 # classes. Is there any thing special about the motor in the 66?
Rich
Rich
12-07-2000 07:23:59
CORRECTION I just received an email from a club offical and steel wheels are allowed.
MCL in IN
12-07-2000 06:34:23
77 and 66 are pretty much the same except for 6 cyl vs 4 cyl engine. For the same or less money you can get a 77 and have more tractor. We tried both--the 77 is far better. Depends on local rules. Are you pulling distance or percentage? In central IN we pull a lot of % pulls and as a rule lighter is better. A 77 will generally do better than an 88 because of less weight. I have a field ready 77 that weighs around 3900. Sometimes I win--sometimes I donate. The beauty of a % pull is that if they run an 18" drawbar and low gear they take away the hp advantage. Makes it nice for a lot of guys to go out and have fun. Beware of the bitcher though. There is one at every pull. I got run off from one pull over some mismatched tires. Have a Super 88 with 14.9-38's on 14" rims. Someone complained that tire is supposed to be on a 12" or 13" rim. I didn't even think about it. They held air and were better than the ones that came off. Probably some Deere guy afraid of getting his butt kicked by a superior tractor. If you are going to pull distances and want to be competitive you better have deep pockets whatever you get.
Rich
12-07-2000 04:58:47
We don't have many pulls that have weight classes below 3500#. What would it take to make a 77 competetive @ 4000#?
steve from mo
12-07-2000 05:09:13
 Re: Re: Pulling Tractors in reply to Rich, 12-07-2000 04:58:47
I don't know what all you have to do, (assume steel wheels and no hydraulics) but people talk about stripping 88's down to 4000#. That would seem to me be better than a 77.
Justin Johannsen
10-02-2002 07:07:54
 Re: Re: Re: Pulling Tractors in reply to steve from mo, 12-07-2000 05:09:13
I have pulled a 770 for years. I have it stripped, no hyds, pressed steel, and it weighs in at 4450. A 88 is heavier to start with. Good luck.
Bill
12-07-2000 16:35:09
The 88 can go down to 4000# and below but requires a fair amount of work to do so. If you are required to run the PTO, it is even more difficult.
If you want a light 88 you need to find one with band brakes. ie older than 51 model. The only problem with running the 88 in the 4000# class is you cannot put enough weight on the front to keep it down, which means an adjustable hitch. The 88 is probably easier to get more hp out of for the smaller classes. Go with a gas.
Any other questions, email me.
your missing a lot
12-06-2000 20:09:12
The 60, 66 strip down to 2500. I've only seen one WD that light. The 60, 66 own the 2500, 3000. The WC's are up to the 3500. Different weight class tractors.
your missing a lot
12-06-2000 20:08:07
your missing a lot
12-06-2000 20:06:08
larry
12-06-2000 14:44:53
Around here the 66,s66 and 660 do well. the 60s are under powered.
