88 Front Cowling
Jim
12-05-2000 10:53:24
The front cowling on my 88 is welded to the radiator mounting brackets at the bottom. Is this supposed to be this way or did some overzealous welder get a hold of it.
Thanks,
Jim
jld
12-05-2000 17:58:01
 Re: 88 Front Cowling in reply to Jim, 12-05-2000 10:53:24
Photo might help - from inside the nose. Radiator and it's frame rest on the channels and attach with 3 bolts on each side. Bottom on this nose has cracks that need welding.
Bill
12-05-2000 14:53:26
The bottom mounting bracket is spot welded onto the sides where the radiator bolted to. Some do come loose and that is one way of putting it back on. The very bottom pan that covers the steering is spot welded also but also comes loose on some tractors.
Canada Grant
12-05-2000 11:25:22
Sorry the welder got you ! The rad is held in with three small bolts on each side
