Biggest 4wd oliver tractor?
Gary Moss, Jr.
12-04-2000 09:42:07
what is model # of the biggest 4wd tractor oliver ever made? would like to see picture also
Andy
12-07-2000 19:52:42
 Re: biggest 4wd oliver tractor? in reply to Gary Moss, Jr., 12-04-2000 09:42:07
What is the going price for a decent shape 2655? Range?
Wayne S.
12-10-2000 15:47:00
 Re: Re: biggest 4wd oliver tractor? in reply to Andy, 12-07-2000 19:52:42
Information on the Oliver 2655 along with pictures that may be out there. Thanks, Wayne
jld
12-05-2000 17:31:08
2655 diesel from Oliver Gang Plowday.
larry
12-06-2000 14:52:47
 Re: Re: biggest 4wd oliver tractor? in reply to jld, 12-05-2000 17:31:08
Great picture my 2655 has the white flair strip on the right side of the engine hood. My cab is white on the top and there is a white emblem on the front.
MCL in IN
12-05-2000 10:21:46
Largest articulated 4wd was the 2655. Was a Moline A4T-1600 painted green and white. Could also be bought as a White Plainsman. These were built during 1969 to 1971 as far as I can tell. The factory engine was a 585 ci MM engine. Most were diesel but I believe you could get an LP. Oliver claimed 169 PTO hp but Nebraska tests showed 143 PTO hp.
The owner of the White dealer I used to work for said there was a conversion for those tractors. The dealer would order in a diesel model and get an 800ci MM LP power unit then swap out engines. He claimed to have sold 3 like this. He got them with no PTO so the only way to set carburetor under load was to ride it in the field while farmer was plowing and set them on the fly. Would pull 10 bottoms he claimed. Would send a picture but my scanner quit for some reason and I haven't taken time to find out why.
Wrenchbender
12-06-2000 16:20:22
 Re: Re: biggest 4wd oliver tractor? in reply to MCL in IN, 12-05-2000 10:21:46
MCL, your story sounds like the one I used to hear told when I worked at the White/Oliver dealership. I can't figure out who you are by your initials, but if you know me , my E-mail is my name. Please reply. Thanks WB.
larry
12-04-2000 16:53:15
2655 i can't scan a picture of mine. It's realy a MM a4t 1600. Some guys claim that moline made some with larger engines,but i have not seen them in oliver green.
Gary Moss
12-05-2000 18:38:14
 Re: Re: biggest 4wd oliver tractor? in reply to larry, 12-04-2000 16:53:15
Thank you all very much thepicture was great!
