Electronic ignition OC4 gas with magneto
D.Groff
12-02-2000 18:04:16
Is there a way to get electronic ignition on an Oliver OC4 gas, 1957 with a magneto? I was told if it had a Delco distributer it could be had, but if it had a magneto, it could not. Is this true? If so am I stuck with points?
D. Groff
Dianne
12-07-2000 05:23:47
 Re: electronic ignition OC4 gas with magneto in reply to D.Groff, 12-02-2000 18:04:16
Sorry for long delay - haven't been here in awhile.
I presume your OC-4 has a 3-cylinder Herc?
If you are desperate, there is a company making electronic ignition for aircraft engines. The take the mag, gut it, and put their electronic system inside. It would be expensive, it would be 12 volt, but I hear they work really well. A 6-cylinder aircraft mag could be eaisly modified to run a 3-cylinder Herc.
