550 hydraulic pump
Canada Grant
11-21-2000 19:43:00
When you have the hydraulic pump apart the service manual tells you to reassemble pump with ring indicator pointed in direction of pump rotation. What way does the pump rotate??? It fails to mention this!! Standing at the rear of the tractor is it clockwise or counterclock . We have located a new replacment vickers pump considerably less than what white wants for repair parts its the rotation that has us stumped.
B A Star
11-21-2000 22:37:36
 Re: 550 hydraulic pump in reply to Canada Grant, 11-21-2000 19:43:00
The Hydraulic pump turns the same direction as the engine. Engine pressure plate has a shaft into it with a gear that drives an idler gear. Idler gear drives the pump gear.
