Shifting pattern
steve
12-25-1998 08:44:34
I have an early Oliver 60 and I am interested in how many gears it has, and the shifting pattern. We are used to the newer models with 6 forwards and two reverses. Are the older 60s the same?
OC
12-25-1998 13:36:57
 Re: Shifting pattern in reply to steve, 12-25-1998 08:44:34
the pre 1944 60's had a 4 speed trans with 1 reverse, two neutrals and a two speed belt pulley. the belt pulley is also controled by the gear shift lever, forward gives you R,1&2 and low speed belt pulley,. rearward, 3&4 and high speed belt pulley. the shift pattern is the same as the newer 60's without the two fifth gears and high reverse.
