Need help Identifying this tractor new to me.
mark matuszyk
11-09-2000 06:56:17
serial-226-493-676 model-575-22247 plus on this tractor it has hydraulics steering and it dosent work or the 3-point either.put new pump on it but that didnt do it does any one have a good suggestion on this .
larry wolfe
11-09-2000 09:53:44
 Re: need help Identifying this tractor new to me. in reply to mark matuszyk, 11-09-2000 06:56:17
if its a 1755 the mutiple valve that regulates the flow to all parts of the system needs to be cleaned or unstuck.Its the large valve to the right of the pump near the tire.Allso the air must be bleed from the filter.I hope you changed the filter with the pump.The compensator valve also likes to stick.
Chris Losey
11-09-2000 08:10:24
Looks like a 1971 1755 diesel with adjustable wide front axle.
