Upgrading a 77
L.Hud
11-02-2000 15:14:32
I am new in the Oliver business. Have a 77 and I would like to upgrade the engine. I have been told
that there is a 12 port engine in later model Oliver's. If this is true, I would like to know what models it is and the type of engine. I have also been told the oiling system in the late models are superior to the older 77. Any info would be appreciated.
larry wolfe
11-03-2000 09:37:29
 Re: Upgrading a 77 in reply to L.Hud, 11-02-2000 15:14:32
The lube system is the same in the 1550 and 1555.The 1650 and larger tractors had a full flow and preasuized crank lube system. The cooling system had larger holes in and between the water pump and block. The power increase came from the change to aluminum pistons and other things like the compresion increase. I have seen maney older tractors have increased bore aluminum pistons instaled and run fine.
Oliver Matt
11-03-2000 06:34:36
I am not sure what you mean by 12 port. I know Oliver added 2 more water jackets behind #6 cyl from block to head on later engines in the 1960's but never on the 77. I also don't know of any upgrade of the lube system on the 77 (or Super 77 or 770 for that matter). As far as I know the engines lubed just fine. We have had 2 77's (only 1 now) not counting one my dad farmed with years ago and never had any cooling or lubrication problems with any one of them. If anyone else out there knows something about this I would like to know also.
L.Hud
11-03-2000 16:54:00
 Re: Re: Upgrading a 77 in reply to Oliver Matt, 11-03-2000 06:34:36
Thanks of the info. I have heard that some later models had a twelve port engine and they would bolt in the 77. What little experience I have had with engines, the twelve port engines seems like an easy to upgrade for hp and durability.
Bob K.
11-03-2000 19:05:53
 Re: Re: Re: Upgrading a 77 in reply to L.Hud, 11-03-2000 16:54:00
What on earth is a 12 port engine ???
Mo Ports
11-05-2000 11:09:38
 Re: Re: Re: Re: Upgrading a 77 in reply to Bob K., 11-03-2000 19:05:53
The twelve port head has twelve ports. 6 intake, 6 exhaust, like it is supposed to. If your ready to change I think you better get the camshaft to match the cylinder head. Have been told the head bolts won't match either. Looks like alot of work. Why don't you just get the entire engine. And be done.
Bill
11-06-2000 15:31:17
 Re: Re: Re: Re: Re: Upgrading a 77 in reply to Mo Ports, 11-05-2000 11:09:38
The head will not fit on the 77 block because the cylinder pattern is not the same. The engine block is also a different length.
The 12 port head engine (out of a 1750, 1800, 1850, etc.) will fit in the frame but the bolt pattern for the frame and block are slightly different. The bell housing, flywheel, and back plate would have to come out of a 77. The fan will not work in the radiator. You will have to go to an electric fan. The input shaft coupler may not bolt up correctly either. These are all things to think about when changing. There may be other things also that need to be changed. It will not be an easy switch.
L.Hud
11-04-2000 18:11:11
I guess the correct termnology is a 12 port head.
Later Wak. engines were either equipped with a 9 or a 12 port head. Engines with the 12 port head should be more durable and produce more hp. If it had been a flat head engine , it would have been a 12 port engine.
Jerry B
11-07-2000 17:42:59
 Re: Re: Re: Re: Re: Upgrading a 77 in reply to L.Hud, 11-04-2000 18:11:11
A head from a 1750 will bolt onto the block of a 77. The back two bolt holes in the head will have to be elongated to match the bolt location in the block. (asuming the 77 and 1750 have the same relationship as the 88 and 1850, which I have worked with before.)
The intake and exhaust valves in cylinders 2 and 5 will have to be reversed from their original position in order for them to fuction as they should. This would require a machine shop. In other words if you just bolt the head on and run it (it WILL run) the intake valve will act as an exhaust valve and the exhaust valve will act as an intake valve on numbers 2 and 5. Switching cam AND lifters from the 1750 will correct this problem however.
As far as bolting in a larger engine, it will bolt in and work fine. Just keep the clutch and pressure plate and maybe even the flywheel from the 77 so the transmission input shaft will still fit the tractor/engine combo.
I happen to have stumbled across (and bought)an 88 that has had a 77 engine installed and EVERYTHING bolted up correctly from frame holes to trans shaft. The input shaft required cutting and lengthening, but that "ain't no hill for a climber" as the saying goes. The fuel tank supports required 2 short shims but that is about all.
I have checked the bolt hole position in the frames of my Olivers enough times to know there are no frame or engine modifications needed to transplant engines from one tractor series to another. A friend of mine has the engine from a Massey Ferguson 1100 transplanted into his Oliver 77. The only problem he had was the oil pan was shaped differently from the Oliver pan and he had to replace it with one from an 88.
Oliver engines swap much easier than some folks would have you believe. I had a guy on here tell me not long ago that an engine from a Super 66 or Supper 55 would NOT fit my 60. He said that mounts would have to be fabricated and that alignment would become a problem. Of course he never even looked at or measured the bolt hole location on the frame or block of either one. If he had he would have found out that the holes are in exactly the same place for the 60-66-55-550-660. I know they are because I went and measured them on my fathers tractors and on the ones at the salvage yards.
Don't let anyone tell you you can not put any bigger engine in your Oliver because you can. Yes you may have to have a little machine work done but in the end it will be worth it.
Bill
11-08-2000 15:41:35
 Re: Re: Re: Re: Re: Re: Upgrading a 77 in reply to Jerry B, 11-07-2000 17:42:59
The 1750 head and bolt pattern is the same as an 1850 gas. The head will not fit on a 77 block. The length of the blocks are different and so are the cylinder hole patterns. This is a fact.
The only cylinder pattern that was the same as the 77 was a S77,770,1550, and 1555. There may be others out there but they were not made for Oliver or White. They would have to come from waukesha.
You can however bolt that head onto a 88 with some changes to the bolt pattern and yes as you stated, the holes in the back of the head depending on what year and style 12 port head you are using.
Yes, the 88,99,1650 etc. engines will fit in a 77 but the bolt holes are very slightly different. I have done it myself, I do know. The position of the fan/water pump also creates a problem with hitting the radiator without moving it from its original position. There are a number of things that will change when this change is made. It is not a direct drop in as you stated.
