Need Oliver 770 Clutch help
Fred Miller
12-23-1998 17:35:05
About two years ago we replaced the clutch and throw-out bearing in an Oliver 770 with the power booster. At the time the pressure plate looked good and felt like the spring tension was good. Ever since, it has been hard to get in and out of gear and getting worse. Because of that, we had the clutch adjusted to it's maximum.
Yesterday I pulled the engine out of the tractor and found the bearing and pressure plate forks very worn. This tractor has not had excessive use in the last two years. Is it possible that the clutch adjustment kept the bearing up against the pressure plate and wore the forks? Any ideas why the clutch always drug? The installation looked good but I wonder if I could have installed the bearing backwards. I put the smooth side of the bearing against the forks of the pressure plate. Any thoughts or ideas? I thank you in advance. Merry Christmas.
john hume
12-31-1998 14:59:02
 Re: Need Oliver 770 Clutch help in reply to Fred Miller, 12-23-1998 17:35:05
You may want to look at your pilot bearing, it is inside of the flywheel and the clutch shaft goes into it, if it is dragging, the shaft would still turn even if the clutch is disengaging. If you have had no free travel and the throw-out brg. has been riding against the clutch fingers, it is more likely the clutch would have slipped instead of being hard to get in gear. Hope this helps.
Shadetree
12-24-1998 07:50:25
Fred you will need to chek and make sure that you clutch plate is not warped. Put it up against the flywheel and make sure that it lays flat against the flywheel. Now install the pressure plate whether its new or not check the gap between the fingers of the pressure plate and the pressure plate cover. They should all be even, using a ruler calibrated in 64ths of an inch. If they need adjusted adjust them at the nut in the middle of the pressure plate cover above that finger. After putting the tractor back together check the free travel of the clucth pedal, you should have between 1 and 1 1/2 inchs of free travel. That is the travel that it takes for the throw out bearing to make contact with the fingers of the pressure plate. Good luck
