1650 Oil Leaking into Brakes
Tom
10-30-2000 14:33:00
I have 1968 Oliver model 1650 that is leaking oil into the housing for the brake on the left side of the tractor. I pulled the cover and removed the brake parts to try and replace the seal. The replacement seal appears to be behind the entire housing for the brake assembly which looks like if I pull 4 more bolts I can get to. Am I on the right track? Any other advice in completing this repair would be greatly appreciated. Thanks in advance.
Super tractor puller
10-31-2000 11:20:40
 Re: 1650 Oil Leaking into Brakes in reply to Tom, 10-30-2000 14:33:00
Tom I do not know if you are done but you do not have to do that. Get a small drill bit and drill a hole in the seal, put a punch in the hole you drilled and you should be able to pry it out. That or you should be able to drive a screw driver in beside and pry it out.Hope it works .
D Neubert
10-30-2000 15:43:07
yes
