White 2-44 FL Forklift
S. Frizzell
10-17-2000 18:26:21
I have a White 2-44 FL rough terrain forklift which I am trying to find information on (ie. year of make, engine manufacturer, recommended fluids and capacities, etc). I can not find any White manuals on it and since it seems to be based on an Oliver tractor, can anyone recommend a source and for manuals and the tractor it is based on?
The following is what I know:
White 2-44 FL Model: 515-71011 SN: 248-539-483 4 cylinder gas Paint is yellow with green underneath
Also, the transmission has two levers. One for forward and reverse. The second lever is in an 'H' pattern with two positions to the left of neutral, and two positions to the right of neutral. However, the right hand position seems to select a lo and hi range. (With the shifter removed, there are two rods that the shifter engages, one with one notch and the other with two notches). Does this make sense?
Any information would be appretiated.
Thanks in advance,
Steve
Sherry
10-17-2000 19:18:09
 Re: White 2-44 FL Forklift in reply to S. Frizzell, 10-17-2000 18:26:21
Steve,
Your forklift is based on an Oliver 550. Yours is a 1974 model powered by a Waukesha/Oliver 155 CID engine. The right hand position on the transmission seems like a high low because it is not an H pattern. I don't know exactly what kind of pattern you call it, but here's how it should work. There are 2 neutrals. Both of them are on the right side. Move the lever all the way up (forward.) Now move it to the left. From there if you push the lever up you'll hit 3rd. Pull it straight back from there and you'll find 4th. Now take the lever back to the right (neutral). Pull the lever straight down (still in neutral). Now move it to the right again. From there if you push it forward you'll hit 1st and straight back from there is 2nd. If you're totally confused by now, send me your fax number and I'll fax the diagram. The other lever is definitely for forward and reverse. 4 speeds in each direction. I have several pieces of literature for this model along with all the specs. I would be happy to copy them for you if you'd like.
Mona
03-31-2005 21:45:35
 Re: Re: White 2-44 FL Forklift in reply to Sherry, 10-17-2000 19:18:09
Miss Sherry, My name is Mona Forrest I am from Arkansas.I am sorry for the intrusion on your time but, will appreciate any help that you might be able to give us. My husband searched for hours on the web before he found your reply on Yesterdays Tractors way back in 2000. In that reply you stated that you had several pieces of literature for this model along with all the specs. I was wondering if you still had that literature
if maybe you wouldn't mind copying it and e-mail it to us? Or if you don't have a scanner I would gladly pay you for your troubles. If this is to much to ask of a total stranger I completely understand. Again thank-you for your
time. Sincerely, Mona
GOD BLESS YOU
