Electrical grounding
Jim
10-17-2000 10:11:03
I want to change my Oliver 60 from a negative ground to a positive ground. What all is involved besides merely switching the battery cables?
Bob M
10-23-2000 06:41:03
 Re: Electrical grounding in reply to Jim, 10-17-2000 10:11:03
Besides swapping the battery cables, you need to do two things: 1 - Reverse the connections at the ammeter, and 2 - Repolarize the generator: With the battery connected, use a jumper wire to momentarily connect the "BAT" and "GEN" terminals on the cutout or voltage regulator.
Jim
10-27-2000 14:43:20
 Re: Re: Electrical grounding in reply to Bob M, 10-23-2000 06:41:03
Bob, thanks a lot!!!! Do I switch the battery terminals first or last?
