Two bottom Plow
Terry
10-14-2000 14:11:51
I beleive I have a Oliver Two Bottom Plow mounted on rubber tires. It appears to be in good shape but I guess something, probably a spring is missing on the trip mechanism. When I manually drop to plow it automatically pulls itself back up with the wheel. I can't make it stay down to plow. I would like to know where I can obtain a manual, probably even a parts manual would work.
DKaiser
10-15-2000 09:48:16
 Re: Two bottom Plow in reply to Terry, 10-14-2000 14:11:51
We've had a couple of those with the same problems that we have fixed. You'll have to excuse me because I don't know how to describe some of these parts, but I'll do my best. What we did with one of our plows is replaced a few of the springs, specifically the two small springs with in the trip mechanism itself and the big coil spring on the back of trip. We bought a 4240 a couple years back and this spring was broken, so when we dropped the plow it raised back up again. That would be my guess as to what is happening. Most of the plows I have seen the springs are broken and washers or spacers have been added to try to fix it, but it still doesn't work properly. There are also supposed to be two springs on the trip handle and if any of these are missing the mechanism may not work properly either. If you need parts check agco. We bought a couple of the big coil springs and also some of the small springs inside the mechanism. There may still be some around.
Terry
10-15-2000 03:45:13
I believe it has the rooster lift. It has a arm on the left hand side that engages a set of rollers on the wheel that lifts the set of plows.
DKaiser
10-14-2000 17:12:18
What kind of lift does it have, the rooster comb or a clutch lift. We've had problems with both. Let me know and I'll see if I may be able to help.
