660 or Super 66
Mark
10-10-2000 21:18:49
I found a Oliver super66 or 660 i don't which it is I think it's the super66. THis has the rounded front end Did the 660 have the square front end like the 770 and 880 had.
Bill
10-12-2000 15:18:00
 Re: 660 or Super 66 in reply to Mark, 10-10-2000 21:18:49
The super 66 and 660 had a frame that had the mounting pads on the sides and the squared off front (frame only). The grill was the same from the 66 thru 660. The only thing that changed basically was the colors. The best way to tell is the manifold or serial number.
Scott Green
10-12-2000 03:21:57
Mark , your answer is wrong. The "660" never had the squared front grill like the other 3 didget tractors. I've owned and operated many Oliver tractors , but never a "660". But , from what I've sean and read , The Oliver "660" was the same tractor as the super "66". I see more and more faulse information on this board.
LazyHorse
10-11-2000 18:16:33
If your tractor has the rounded front end it is a super 66, the 660 were the later style, and had a square off nose
Scott Green
10-11-2000 03:25:28
From what I have read , they are the same tractor , just different color combinations. Oliver may have changed little thing like the exaust outlet. Scott
Betty Starr
10-10-2000 23:00:49
Super 66 and the 660 had the same sheet metal. The easiest way to identify other than the serial number is the exhaust manifold design. The Super 66 has the outlet in the middle at the top. 660 has the outlet in the rear on the side with a cast manifold bolted to it to bring the exhaust to the center.
If the tractor has a serial number higher than 73 132 its a 660.
