Losing hydrualic fluid
Lonnie Jones
10-05-2000 12:50:56
I have a 1855 and I am getting a lot of hydrualic
oil being blown back through the breather plug
on the back of the tractor.It is located to the
left and below where the hydrualic fluid is checked.
Wrenchbender
10-05-2000 20:20:45
 Re: Losing hydrualic fluid in reply to Lonnie Jones, 10-05-2000 12:50:56
That breather is where you add oil to the trans/rearend. Your post said "losing hydrualic fluid",are you losing it from the hyd resevoir or is it just coming out the breather? If the trans/rearend is filling up and it is going out of the resevoir, I would suspect the o-ring seals on the PTO pistons. If you cap off the two small lines going to the PTO valve and the oil level stops rising,then you have found your problem by isolating the PTO. Good luck, WB.
