Ether starting
Paul Stanley
12-19-1998 22:16:16
I was reading in one of my Oliver books that some of the Oliver models had a 1/8 hole in the preheater for using ether. I have an Oliver Super 55 diesel and want to know if I can add this to my tractor and what is the exact procedure for applying the ether? Thanks and Seasons Greet
Dennis H.
12-20-1998 11:35:39
 Re: Ether starting in reply to Paul Stanley, 12-19-1998 22:16:16
Egor posted on the talk page, but the basic idea is to crank it to get the oil through the journals and then apply a 1 second squirt to the breather and crank it again. If it "hits" but doesn't start repeat the process but don't increase the amount of spray or you will hear a symphony of wrist pin and rod bearings clattering in agony...
Adam
12-21-1998 15:26:50
 Re: Re: Ether starting in reply to Dennis H., 12-20-1998 11:35:39
I would not use either I recently rebult a super 77 engine 3 rods were slightly bent Not noticable to the eye but the guy who put the wrist pin bushings in for me had a tester of some sort and discovered it. said it's commen for diesel rods to be like this,It robs power, cause Either. a super 55 has the same rods and pistens as a s77.
Paul Stanley
12-21-1998 22:04:01
 Re: Re: Re: Ether starting in reply to Adam, 12-21-1998 15:26:50
Thanks for the information. Sounds to risky to use. One of my neighbors said it can put a hole in a piston. I have a in line heater core that is in the lower radiator hose. I am going to try and find a cord for it. Seems like the safer way to go. I want to rebuild this engine one day, but on my terms. If you know what I
