Need help with 3 point hitch hydraulics!!!
John P.
10-02-2000 14:59:44
Help! Almost as fast I can fill the 3 point hitch hydraulics, it is pumped over into the transmission/differential sump. The tractor is a 1955 Super 55, and I am not all that familiar with its internals.
John P
10-09-2000 16:01:57
 Re: Need help with 3 point hitch hydraulics!!! in reply to John P., 10-02-2000 14:59:44
Thanks Gary and Jason. It turned out to be the hydraulic oil pan. It had become perforated in two places. Luckily I had access to the pan from a 550 which seems to match up exactly.
Jason
10-03-2000 20:10:22
there is a tin pan that holds your oil between the hyd and your rear end, there is probable a hole in it. 9 times out of 10 that does it. hope that helps if you need any parts let me know i can get them.. jason
Gary
10-02-2000 17:53:55
The seal is probally out of the hydraulicpump
Gary
10-02-2000 17:53:42
