Identify
Mac
10-02-2000 09:07:07
I have an old Oliver I am trying to identify.Where is the model number or is it gone. The engine has a ser.# D600A619. It is a 6cyl , 2 front wheels. My guess it was made early 50s to early 60s. Help!
Sherry
10-02-2000 18:39:43
 Re: identify in reply to Mac, 10-02-2000 09:07:07
There should be casting numbers on many of the cast parts. The number will start with a K or an L or some other letter. Those letters will help identify the model. Give me a few part numbers and I'll tell you what it is.
Mac
10-03-2000 14:02:06
 Re: Re: identify in reply to Sherry, 10-02-2000 18:39:43
The steering gear box has a number F756. Clutch pedal #F989. Right brake pedal #F111. Maybe I could post a picture or E-mail one.
Sherry
10-03-2000 19:49:03
 Re: Re: Re: identify in reply to Mac, 10-03-2000 14:02:06
The F was the designation given to parts on the Oliver 70 Standard, Industrial and Airport model. You didn't say if you had a wide or narrow front but I'm guessing by the numbers that you have a wide front. It should be a 70 though. Is there any red paint on it by any chance?
Mac
10-05-2000 19:03:46
 Re: Re: Re: Re: identify in reply to Sherry, 10-03-2000 19:49:03
It has a wide front end.
Mac
10-05-2000 19:01:02
Under the green paint is a bright orange.
Sherry
10-05-2000 19:43:09
 Re: Re: Re: Re: Re: identify in reply to Mac, 10-05-2000 19:01:02
Congratulations. It sounds like you're the proud parent of a 70 Industrial. Most likely built in the mid 1940's. A good find!
Mac
10-05-2000 22:00:25
 Re: Re: Re: Re: Re: Re: identify in reply to Sherry, 10-05-2000 19:43:09
Thanks Sherry
Karl in MD
10-02-2000 21:29:47
If I'm not mistaken, that's a Continental Motors casting number. Continental+ six cylinder+ tricycle front= Oliver 70 Row Crop? My best guess, Karl.
Steve in CA
10-03-2000 17:49:29
 Re: Re: Re: identify in reply to Karl in MD, 10-02-2000 21:29:47
Did Oliver ever use a Continental 6-cyl engine? The styled tractors all used either a standard Waukesha engine, or an Oliver built Waukesha design. The only exception I can think of is the GM turbodiesels in the 99, and 9xx series.
I think the Super 44 and 440 may have used a continental 4-cyl engine.
Karl in MD
10-04-2000 11:08:19
 Re: Re: Re: Re: identify in reply to Steve in CA, 10-03-2000 17:49:29
The engine in the Hart-Parr and Oliver 70s was an overhead valve six-cylinder 201cid Continental. The 60 used a Waukesha, and all the fleetline series used Waukesha engines, with the exception of the Detroit in the S99 and later. The 80 engine was descended from a Hart-Parr design and the 80 diesel used a Buda. Oliver outsourced engines right up to the end, with the Perkins in the 1850 and the Waukeshas and Hercules in the 50-55 series.
