Bleeding hydraulic rams on a loader.
Ian Johnston
09-26-2000 13:03:12
How do you bleed hydraulic rams on a tractor. ?(Cockshut 540)
Which do you do first - the 3P hitch or the rams?
I have bled Brakes but that is all the experince i have had.
larry
09-26-2000 14:53:44
 Re: Bleeding hydraulic rams on a loader. in reply to Ian Johnston, 09-26-2000 13:03:12
If double acting just move them back and forth a few times, no real bleeding needed.
Ian Johnston
09-26-2000 15:55:41
 Re: Re: Bleeding hydraulic rams on a loader. in reply to larry, 09-26-2000 14:53:44
The two rams on the arms are only single action.
larry
09-27-2000 09:24:28
 Re: Re: Re: Bleeding hydraulic rams on a loader. in reply to Ian Johnston, 09-26-2000 15:55:41
Sometimes you need to add wieght to push the rams together while holding valve. On my tractors i don;t bleed single acting cylinders at all. On my truck there is a small plug to loosen near the end.
