OC-3 SPIN ON FILTER
also on my Avery A ???
Alberta Mike
09-24-2000 16:29:11
I was looking through a magazine the other day and noticed an Oliver (Cletrac) OC-3 crawler that had a spin-on oil filter mounted (upside down) near the top left side of the engine block, above the generator. Now, I believe that crawler has a Hercules engine does it not? Anyways, my Avery A has a similar filter in the same place (although the guys in the orphans and oddballs forum say it's not supposed to have it). The Avery also has a Hercules engine. The filter that was on it when I got it was a Case factory brand, probably the same one from the VA series. Does this all sound correct to you????
Eric Severance
09-29-2000 19:14:49
 Re: OC-3 SPIN ON FILTER - also on my Avery A ??? in reply to Alberta Mike, 09-24-2000 16:29:11
All sounds correct to me . The early Avery A's had spin on filters , like the HG's , and OC-3's . The later Avery A's had canister type filters , which were also on the left side , while the OC-3's kept the spin ons .It will depend on the year of your tractor , as to weather your spin on is politically correct . I'm guessing prior to 45 , or 46
Dianne
09-28-2000 13:03:32
My OC-46, 1957 or 58, has a spin-on filter on a Hercules GO-130 engine.
larry wolfe
09-25-2000 09:06:33
This filter was used but maney of the tractors got the other style filter. It depends when they were made. This filter was popular used on AC WC,Oliver 70 etc.
Albert (Sparky) Duroe
09-24-2000 21:50:38
They both have the same motor an IXB-3 hercules; Avery purchased the General tractor line from cletrac in 1942 and renamed it the Avery A. If you look closely the hood, sides,fuel tank,clutch and bell housing are also the same.
Delbert
09-24-2000 19:37:19
LOOKING at my OC-3 parts book, there is a filter, it is on the left side in back of the generator. Hope this helps. Delbert
