Oliver 550 / 55 Parts
Don
09-17-2000 14:57:42
What is the differance between a model 550, a model 55, and a super 55? What parts are interchangable? If I buy a model 55 parts tractor, will the transmission, PTO, 3POINT LIFT, etc. fit my model 550?
B A Star
09-18-2000 22:43:14
 Re: Oliver 550 / 55 Parts in reply to Don, 09-17-2000 14:57:42
Oliver only built the models Super 55 and 550. There was not a model 55. The tractors are basically the same, piston bore was 3 1/2" in the Super 55 and 3 5/8" in the 550. The larger bore sleeves could have been installed later.
Mike M
09-18-2000 08:52:16
The 550 was the "improved version" of the Super 55, which was the "improved" 55. The tractors are built on the same basic platform, but some parts will interchange and some will not. The only way to tell for sure would be to get parts manuals for both, and compare. I recall a neighbor having a 55 or Super (not sure which) on which he had problems with the PTO shaft breaking- I have a 550, and operated another in my youth, with no such problems, so I suspect that they improved the PTO for the 550. 3 point is probably interchangeable.
Don
09-17-2000 15:02:04
correct E mail address in my prior post should be [email protected]
