Flate rate time for 88 work
Clay Schreiber
02-08-1998 16:44:01
Have had a dealer put bearings (Main,rod, front,and rear seals) head was not pulled, but dealer pulled engine out as they also replaced clutch. My question is what would be the hrs. for such a job? Ideally from a flat rate manual or from your own experience..thanks much in advance..
kevIHC
03-08-1998 20:34:21
 Re: flate rate time for 88 work in reply to Clay Schreiber, 02-08-1998 16:44:01
: Have had a dealer put bearings (Main,rod, front,and rear seals) head was not pulled, but dealer pulled engine out as they also replaced clutch. My question is what would be the hrs. for such a job? Ideally from a flat rate manual or from your own experience..thanks much in advance.. I did a simalar job to an 880 and if parts were right there 6 to 7 hrs would have been plenty of time
