Pulling hubs on a Super55
Paul Stanley
08-24-2000 22:24:09
I am going to have to pull the hubs off my rear axle soon to replace some seals. Cheer me up and tell me it aint that bad! Anybody have any pointers. I plan on using a flat bar puller, gentle tapping and lots of Marvel Mystery Oil. Will I have to use heat? I got the U-bolts undone without much trouble. By the way, the axles are already removed from the tractor.
larry wolfe
08-25-2000 05:15:26
 Re: Pulling hubs on a Super55 in reply to Paul Stanley, 08-24-2000 22:24:09
When the u bolts are loose I rotate the wheel and let the wieght of the parts pull the hub loose. Then oil the space in between and then slide them off. If the bolts don't hangup they slide easy. With the axels off I would remove u bolts completely and use a press, but a good puller should break them loose.
Dan from PA
08-26-2000 00:38:59
 Re: Re: Pulling hubs on a Super55 in reply to larry wolfe, 08-25-2000 05:15:26
There's a neat little tool for adjusting/removing these hubs with ballasted wheels/tires still attached. It's a little flat steel stick about 3/8"widex8"long with steel balls in it that stuck out the top and bottom of the stick, every inch or so. Basically a linear ball-bearing. You loosen the u-bolts, turn the keyway to the bottom, insert the stick in the keyway between the hub and axle, turn the keyway to the top, position the hub on the axle, turn the key down, and remove the stick.
Anyone have one of these?
Super 55
08-25-2000 12:29:20
Wow, that came of easy without a puller. I'm surprised. I have often heard of some tractors where the procedure is heat, tap, heat, tap, heat, frustration, tap, etc. and two days later it's starting to budge.
larry wolfe
08-25-2000 17:10:47
 Re: Re: Re: Pulling hubs on a Super55 in reply to Super 55, 08-25-2000 12:29:20
I started to add to my first post be carefull not to let one slip off onto your foot.
